ViewPoint 0
I'm trying to use the dimmer as a switch for a starway with three light switches. The reason I'm using dimmer is, of course, because there is no neutral wire. I wonder if a use of on-by-default wall switches will help me get all three working with the load. Here is a drawing of what I'm trying to get. The current (no dimmer) layout is on the scheme above and what I am trying to get is on the lower part of the drawing.
7 answers to this question
