4 Heat Controller FGT-001 in one heating zone, the Reference Thermostat in the plugin isn't selectable
Fabir
Hello
I have a room with 4 heating radiators and would like to use 4 Fibaro FGT-001 Heating Controllers in 1 Heating zone.
The additional thermostat FGBRS-001 for the Fibaro Heating Controllers, can only be connected with up to 3 Heat Controllers.
Therefore I would like to use another temperature Sensor in this room, as the Reference Temperature Sensor.
My Home Center Light is on Release 4.531 Beta
For testing, I have already 1 Fibaro Heat Controller FGT-001, it is on the latest Firmware 4.5
In the Fibaro  Thermostat &Heating Plugin, that is steering the Heating Zones, I can only choose the Thermostat from the Fibaro Heat Controller, no other Temperature Sensor in the Room, for Instance a Fibaro Door/Windows Sensor.
Is this a bug or a feature?
Thanks for the help in advance
Fabir
Edited by Fabir
3 answers to this question
The main temperature sensor in a room is set from the Room view in the top bar if that is what you are after. Any temperature sensor can be selected there.
  • Momos @
    Hi, thank you for your message.
    I'm talking about the Thermostat & Heating Plugin that is designed to be used together with heating zones.
    Look below, the second picture that's where I can't select another Reference Thermostat than the Thermostat on the Heat Controller
    Best regards,
    Fabir
    Ahh you got me... in all the years with HC2 i had no idea that plugin existed.... i just use the heating panel.
