Different temperature for each room within one zone
martin01_cz
Hello, is there a way to set different temperature for each room (radiator thermostat) within one zone in heating panel?
I already have two zones, ground floor and upper floor, each of them containing few rooms. I wouldn't like to create more zones as it is not very comfortable to make changes or set manual mode for each zone in case I stay working from home or something. The idea is, that the zone would only define time and higher or lower temperature based on presence at home while temperature would be room-specific.
Maybe there I could create more zones with different temperatures and place them to some sort of master zone that would control them?
Many thanks for any idea.
PS I've got the Fibaro HCL
Martin
Edited by martin01_cz
hi
group your rooms by zone here fibaro/en/panels/temperature.html
check is ok
[ { "id": 944, "name": "Zone 1", "mode": "Schedule", "properties": { "handTemperature": 0, "handTimestamp": 0, "vacationTemperature": 0, "currentTemperature": 19 } } ]
yep!
so. now we can create simple VD
  • Thanks for the reply.
    I have the rooms grouped by the zone.
    By VD you mean virtual device? Where can I enter the code? I can only see there some sort of button configuration.
    Sorry, new to Fibaro...
    Thanks.
    Thanks.
    oh! I am sorry!
    >Home Center Lite
    Drop it! It can't be useful for you (your Home Center Lite)
