  • 2
Alexa and TTS on Echo dot 3
Kage
Have search now for 7 days straight  to find something for my echo dot 3 en TTS.
coudn't found what i want.
So meaby it can not be done (hope not)
Is there a way to let the Echo speak what i want. Lets say: if door rings (value 1) then (in dutch) De deurbel gaat
Just like sending a text thru a global like Telegram
i found something with HA bridge on a Pi3 but not sure if this will work
also found
but for now it wont work
hope there is an answer
On 5/15/2019 at 2:48 PM, ianakapilotlight said:
I have plans to add more languages in the future  would you be able to help with Spanish translations?
mol how I can help with translation to Spanish?
Regards
Regards
Great news - The doorbell skill is now available in the Amazon Spain store -
hi ianakapilotlight...
is it possible to do with your skill do do like this...
user ring analog doorbell, fibaro relais realizes this and trigger your script within your skill now ring doorbell video is beeing displayed on all alexa show devices, so that it can be answered?
br
snoopy78
also found
Hi @Kage
the solution You looking for is on the same site
- the only problem is that this is written for HC2.
Do You have HC2 or HC3?
I'm looking for this solution for HC3 but I'm not good enough in LUA to make it fly.
