Fibaro Dimmer included with Bypass
Alex Rob
i thought why is fibaro using a Dimmer 2 and a seperate bypass?
Why not onclude both as one product?  I do belive the size will be bigger but if u have to use a bypass and a dimmer 2 in the same box it will be less space.
Other brands got a dimmer as like xcomfort there it is not necassary to got a extra bypass.
Maybe fibaro could also make the connection terminals better? Like wago?
The terminals on the dimmer2 are really short ended.
