Fibaro Smart Implant doesn't always work with Garage door
play3man
Hello, as there is no forum dedicated to Fibaro Smart Implant, i don't know where to post this question - so i'm trying it here.
I have a Fibaro Smart Implant connected to Garage door. It is connected from Out 1 to impulse output of Garage doors. If this two wires from garage output are connected, garage door will open, close or stop.
As I power source, I'm using external power adapter with 12v output. Implant works okay, without any problems it can be added to z-wave network. Im not using external button with it to open/close the garage. So I only want it to be controlled remotely with mobile/pc etc.
Basically I connected it the same ways as is shown in manual. I also changed all the parameters etc.
The problems is, that with this settings and connection scheme it worked for few hours without any problems, but, after some time it just stopped working without any reason. I tried to readd the Smart Implant to z-wave network, but it didn't help.
If I manually connect the two wires that Fibaro should connect, garage door is working without any problems. I also check the operation of smart Implant with multimeter - it beeped for one second as it should. But, only if the cables are not connected to the garage door. If I connect it to the garage system, Fibaro is just stop connecting it without any reason.
Thanks for your help!
I have it working. I have two Hörmann promatic 2 doors and one wired switch for each door.
I have installed one Smart Implant (firmware 5.2). Switch for opening Promatic nr. 1 are connected to GND and IN1, switch for opening Promatic nr. 2 are connected to GND and IN2 – both on the input side of the Smart Implant (see play3man post trom march 7, 2019 for diagram).
OUT1 and OUT2 are connected to the Hörmann Promatic 2.
I can open, close and stop manually at the switches and through Zwave (I use Home Assistant).
Only problem – if the power to the Smart Implant itself toggles – the gates will open. I have not solved this yet.
