HCL Custom Recovery
  • 3 weeks later...
  • 15 hours ago, lamberts said:
    after used it for a month, i regulary had some freeze and need to restart HCL services... Is anyone encounter same issues ?
    It happened before. Early versions had socket OOM issue which cause CPU overload in a polling loop. As result entire device become slow/unresposable. With the latest releas I have no single crash for 2 of my test stands
    I did not have issues before installing the HUE plugin, will try to revert back and I will keep you posted ;)
    Thanks for your sharing/job
    • 1 month later...
    I have a problem with my HC3 proxy in lua. Some time ago it stopped communicating with HC3. Unfortunately, the debug is empty and nothing displays, who knows how to solve this problem?
    /monthly_2021_04/344150457_Zrzutekranu2021-04-01184103.jpg.61a3db19579458504a1e236e0f03f9e8.jpg" />
    • 3 weeks later...
    Hello, guys! Sorry for that stupid question, but could you advise me how add device in Apple Home. i have created rooms and assign them devices but nothing appearances in HK. Maybe should i start something?
    Hello, again! After rebooting and waiting in 15 min, I have seen devices, but I had new issue “Failed with OSStatus code - 6727 (kNotFoundErr).
    Also I can’t change variable HK_MQTT_OPT_CONTROL_PAYLOAD to value PLAIN. When I make it all variables became NaN
    Edited by Marat
    • 2 months later...
    • 4 weeks later...
    Hi @jack.daniels
    Great job!
    1. Remove variable  HK_MQTT_OPT_CONTROL_PAYLOAD
    2. Open dev tools browser (chrome ctrl+shift+i)
    3. Set script
    4. Call function
    exemple
    5. refresh page and reboot hcl
    • 1 month later...
    Good afternoon, I installed your custom firmware, thank you for this experience and also for discovering the possibility of writing scripts in LUA, but with HomeKit you have trouble, it does not work, there is also no way to get into Homebridge itself and somehow adjust the settings, because everything is designed in MQTT and it is not clear how to edit what. And there is also no way to control it remotely, because he can't understand the apple TV set-top box.
    • 4 weeks later...
  • Hi, everyone
    Regqrding MQTT - feel free to share your sugestions what should be fixed added
    Regarding HomeKit "No response" issue - it's solved in the latest version of the brigde 1.9.0
    Firmware 4.620 is on testing now. I hope to share it really quick.
    Stay tuned
    Update: You will still need a home hub (i.e. ipad, appletv or homepod) for remote control your home
  • HCL 4.620 with HomeKitten 1.9.0
    -Fixed accessory disconnection in background
    -Immediate task termination on signal (was waiting for a current poll to finish)
    -RGB controller support added
    -HAP event notifications coalesce added
    -Mass log messages (for test purposes)
    Enjoy it
    • Like 3
  • With 4.600 I had to crear NRG data every 50-60 days in order system to work. If not - scenes are not running etc etc.
    Lets see how its going on 4.620...
    • 4 months later...
     thank you very much, rely appreciate it!
    I have changed the Value of Variable
     to 'PLAIN', but ERROR Failed with OSStatus code -6277 (kNotFoundErr). Maybe someone knows how to fix the error?
    • 3 months later...
    Hi! Does this custom recovery interface restore the factory "update.7z" file? Or do I have to download a factory recovery file from the fibaro website?
    • 1 month later...
    • 8 months later...
    Sinse now I was not have to clear the history. This is cool.
    Does someone still using the custom firmware? The 4.630 update has promising "stability improvements" in the changelog
