Garage door help!!
Jayjay280
i was hoping someone could let me know what fibaro item and how to wire  I’d need to automate my garage door so I can control via app or google Assistant ?
Image attached - any help would be great :)
    all i I have is this I found on the internet ? It’s just says PM1 on the cover panel no name or company sorry
    nice noname ;)
    but, you can wire with z-wave relay with alternative (Dry Contact Out?!) power here vcwHk7kWAO.png
    one notice here, you can't control done of operation. your device can't send callback command what your door is _full_ opened or _ful_ closed. otherwise, you should buy and mount an additional 2 relays (sensor-end) on top and at the bottom
    FGS-222
    IMHO
    220V used only (!) as main power for FGS222
  • Like this ?
    Edited by Jayjay280
    Sir, IMHO my pic can say more than I
    again
    No no no no
    according your manual
           U=Up
    S= Stop D=Down
    + / - = Dc 12v
    12v NIOT 220v
    220v we are needing for powering Fibaro module (L/N)
    next 12v we are needing for powering remote manual control
    so, while you don’t have Fibaro FGS222 we can playing with your garage door manually
    find power 12v (warning D.C.) and connect to + - respecting polarity)
    Done
    Find short wire and connect (touch) : one wire to + second (touch) to U or D your door must start opening or closing
    Edited by 10der
  • Ok I think I have a old 12v power supply plug somewhere I will try this as soon as I can get a chance to - thank you
    wait, You know, I didn't think to ask.
    can you check BEFORE: what is power/voltage in [+] / [ -] terminals in electrical installation WHEN your device is running (220v - ON)
    my guess - it's not [IN[ it's [OUT]!
    Edited by 10der
    sorry,. left word is not recognized by me.
    Edited by 10der
    ok. that's ok
    but you did not answer me: what voltage on the right block on + and - terminal
    Edited by 10der
