johndeere 9
This problem may not be related to the 3rd party device, but rather to HC2.
I can't change manual parameters (this device does not have template). I can add parameters only if I click on READ ONLY or DEFAULT. Otherwise the parameter does not appear in the list.
The problem is that I cannot change any parameter. If I change it, and save it, then read/sync: it still remains on the default value.
I have 2pcs of this device and I did not have this problem with the previous.
This unalterable parameter problem appeared after the recalled 4.540 update.
Can anyone give me any trick on how to change parameters in this case?
Thanks!
22 answers to this question
