Double switch sceneActivation error
marbe
I use sceneActivation on Fibaro dimmer for some time. Now I need this on double switch.
I checked all check buttons on parameter settings, and use script as usually, but I cannot get it work.
Scene didn't start and no value at sceneActivation.
Has anyone idea?
Thank you
1 answer to this question
Switch works differently...
First of all... use this:
and see the debug result.
I believe it's all help you need to develop the solution :)
You can also create the block scene and change to lua one, and see how it's written.
Edited by pogo
