Battery drain
Sjekke
I find that the batteries of the Fibaro door sensors V2 drain very quickly. I have one here that gives it up after a month = €€€. The configuration is on the default setting except Parameter 2  = Visual LED indications = O.
I also have a V1 + DS18B20 in a garage without heating and without insulation with a lot of temperature difference (even below 0 degrees) and this battery lasts much longer.
Any tips, experience?
V1 = Z-wave protocol = 4.5
V2 = Z-wave protocol = 4.38
HC2 = 4.532 beta
Edited by Sjekke
  • No one :unsure:
    Can I check how many times the sensor talks to the HC2?
    Hi, Sjekke@
    I've also had a Fibaro Door/Window V2 Sensor, it was very unresponsive and multiple batterys have been drained in a few days. I got it replaced by the reseller. The new one is OK.
    Best Regards
    Fabir
