fibaroforum.maki 0
Dear Fibaro Community.
I`m trying to use the new Fibaro “Smart Implant” to close the NO-contact of my gate opener .
For this case the Fibaro manual suggests this wiring diagramm:
/monthly_2019_03/1443521780_wiringaccordingtomanual.png.ba0aba240af1b0600a38868fe0db6638.png" alt="1443521780_wiringaccordingtomanual.png.ba0aba240af1b0600a38868fe0db6638.png" />My gate has a NO (normall open) contact that needs to be closed (connected/bridged) to open the door.
hence I configured Parameter 154 to “0” - contacts normally open / closed when active
The time these contacts are closed is the time where the gate is open. E.g. (10 seconds for example)
Therefore I changed parameter 156 to 10s
To my understanding these settings should work as follows:
a short “activation” on IN1 triggers both contacts of Output1 to be connected for 10s
Now clicking the “ON” button on the Fibaro GUI (graphical user interface) has the desired effect:
the contact between the first and second out1 contact is closed and the gate opens for 10s
The Problem:
It only works via GUI (graphical user interface) Connecting IN1 to GND doesn`t have any effect. The “switch” is not working
What am I missing?
In a second step i`d like to trigger IN1 with a battery. Therefore I configured it to binary sensor.
->nothing happens
What am I missing? Where do I configure the activation voltage and so on? What are the values that IN1 accepts?
In short: how can I put something into IN1 to trigger the outputs?
regards,
Maki
Ps: i also get this weird notification that the device is waiting for syncronization :S
HC2 v4.540
