ALARM
malitan
hİ all,
I Have a alarm device in HC2, I can see it on the left side but unfortunately I cant see it on the main page.
Could someone explain it please its very strange.
thanks,
You can see the it below pictures.
Unset alarm breach or somthing like this (sorry I am away from my PC) category on your alarm device
and magically it can be visible again
IDK why FIBARO develop this behavior and why hide this devices (you want to know dev battery stat? No you don’t)
  • I did already but still I cant see it on the main page :(   why ?
    NO! if you wanna SEE - remove Alarm -Breach to OTHER (for example)
    Edited by 10der
  • I Didnt understand what you mean :)
    Alarm device shouldnt be breach right ?
    1) if you want  to see this device as a normal device - please change Others
    nothing will be changed in device behavior but you will see this device with other devices on the main UI page
    2) if you setup this device as
    you can grab this device like
    nothing others "bargaining chips" here.
