Steinel IS-140-2 parameters unchangeable
aleks
Hi there,
i have some problems changing the parameters of steinel motion sensor.
Due to this blog i tried to set up the parameters:
After first time inclusion of the steinel I only get undefined as value for every parameter.
so i did the following steps.
- excluded
- resetted
- included again
now i get the default values in the parameters but i have no idea how to change the values.
after changing the values and pressing the save button the default values show up again.
Any idea what to do next?
Can anyone explain me why parameter 8 has to be set to 0 to work with the HC2?
As long it seems to work in the default value.
Thanks for your help
6 answers to this question
  • @tinman: Thanks for the link.
    Seems to be a firmware problem in the current version.
    i will try either api or lua and will report if it worked -  but might not be before weekend
    On 4/23/2019 at 10:47 PM, aleks said:
    Hi there,
    - excluded
    - resetted
    - included again
    Same problem over here !
    Try setting them on the master device, not the slave device.
    should work regardless if template is available or not.
    BR - kro
  • @tinman thanks.
    the instruction changing parameters through api work fine for.
    I was able to change all paremeters as described in your tutorial.
    can maybe someone explain me, why the parameter 2 must bei to 2000?
    I have the problem that when motion is detected the lights going on, also when it is day. Can someone maybe help?
