How to wire FGS-222 without neutral
JulienG
Hello - How can I wire a FGS-222 without neutral?
I found many wiring diagram for FGD-212 without neutral but none for FGS-222.
Edited by JulienG
3 answers to this question
Hi @JulienG
In your question you mentioned in the title a FDS-222 switch, later you talk about the FGS-222 Double Relay switch, please clarify what you mean.
AFIK there is no Fibaro FDS-222 switch.
Best Regards
Fabir
@JulienG OK, thank you for the clarification.
The manual for the FGS-222 is here
AFIK the Dimmer 2, called FGD-212,  is the only Fibaro device, designed to be used without neutral.
