Dimmer2 starts always 100%, does not remember dimming level
jadijkstra2000
Hi all,
I have a strange thing with one of my dimmers (I have more...). All dimmers work fine in but with one, when I push the button on the wall, the light goes always to maximum (100%) output, dim function through the push button works, but when I turn the light off and then on again, it starts at 100% again,...al my other Dimmer2 dimmers don't have this issue... they keep the last dimming value in memory, but this one doesn't
Any thoughts about this?
3 answers to this question
  • On 5/15/2019 at 4:01 PM, rustam_batyrov said:
    I did, it is set to 0... strange thing, it does it always now, but it didn't do in the beginning...
    Dimming with the app works fine
  • Other problem:
    Dimmer2 has an other problem.
    With the switch I only can turn on to max, or min, not something in between.
    So, dimming with the switch is not possible. However, the last dimming percentage is stored...
    I can dim with app, no problem....
