Output ON after HC reboot
northyorks
Whenever my HC reboots my door which is controlled by Implant 'ON' opens.... every time.
It seems on booting the HC flicks the output ON.
What could be causing this??????
3 answers to this question
In the template, can you not change the parameter about state after loss of current? You could change it to "nothing" instead of "last state". Sometime it helps.
