In our bathroom we have 2 lightsources; 1 in the ceiling and 1 above the mirror. Both are connected to a double serial lightswitch within 1 housing. I'd like to be able to dimm the lightsource in the ceiling, and leave the one above the mirror as is. In order to do that I replaced the current lightswitch with a Jung 535U and removed the spring in the right switch leveler (for the non-dimmable lightsource abave the mirror). And hooked it all up according to the following schema: aeb87d5b57
