nudelengineering 0
dear forum members,
i have a house with fibaro and hue moduls on a hc2. and also i have build in switches who i build myself they give a 24v puls when touched (capacitive sensors)
and i'm searching for a solution to connect the switches to the hc2 so the fibaro recognises the buttons on the switch.
the voltage of the pulse is 24v now but can be changed to a lower voltage if needed. als o i have the capabillity to connect the buttons (about 83 ) to a siemens s300 plc that can collect the signals and sent them further in the network via ethernet module or serial interface. the difficulty wil be the software between the ethetnet module or the rs232 comunication.
i also can have myself built a electronic board who can collect the signals and comunicate on rs232. but is there a module that can comunicate with z wave or over usb or ethernet that can be read by the hc2
do i need to make a virtual device or something?
does anyone know if this is done before? and is there anyone who can help me with that? i have searched the internet for modules or solutions but did not found anything suitable for my house.
greets noel from holland
1 answer to this question
