PTC/NTC or resitor as sensor?
Smartin
How do I connect a PTC or NTC (thermo resistor) or any other variable resistor?
Is it the same as a 2wire sensor?
Edited by Smartin
@Smartin it is 1 wire and you need a ds18b20 (as far as i know)
I think you can't use PTC and NTC sensors because they are passive sensors, DS sensors and DHT sensors have a serial interface to read the measurements
