lasmartuser 1
Hi... I tried to add the new walli dimmer in dimmable lamps led 6W x3 without neutral cable ( old dimmer2 module is working good in same lamps ) , but i receive always error : VOLTAGE DROP ERROR and it is working only if manual switch brightness under 50%, that is not what i want of cource. I tried even to keep only one led from 3 , but same output. Tried it with other led lamps , and had same ouput. What happens? Anyone that managed to make them working without neutral cable configuration?
I tried all suggestion in manual of walli but didn't work...
"Appearing of an error in a 2-wire connection may be the result of mains voltage drop or a too high brightness level of the light source.
If parameter 37 is set to 1, the device will automatically try to turn on again.
Voltage drop error suggests that parameter 2 value should be reduced until disappearing of the failure. You can also recalibrate the load using parameter 13.
After three unsuccessful automatic tries of turning on the load, Dimmer 2 will stay in VOLTAGE DROP error mode (module turned off)."
Any suggestions please?
7 answers to this question
