Apple Watch missing scenes
Soft
Can someone post a tutorial on how to make this work?, I do see the app on the watch, even scenes, but the ones I have selected does not show.
W dniu 18.10.2019 o 12:32, Romain napisał:
I contacted Fibaro, here is their answer:
Hello Romain,
I’ve heard about this, it is a problem connected with iOS 13, and it should be fixed in patch .561 or .562.
Thank you for your patience.
The same problem on Apple Watch 3 and 4. It’s my favorite and most often used feature. Fibaro when we can expect patch release?
Mam ten sam problem. Brak scen od Fibaro na Apple Watch. Kiedy to naprawią? Fibaro na zegarku jest to co zawsze używałem. Teraz tak jakby odcięto mi rękę.
2 minutes ago, uk45h said:
The new Fibaro app is working with apple watch too bad it is showing all (!) scenes that I have.
The same approach is also with the iPhone widget.
I think nobody from the development team is using these features, and this is the reason they all creating it in such a useless way!
agreed! This is a new paradigm of the home center app. They are pushing this idea of AI showing the most relevant scenes for you. I preferred the old approach which I decided which scene to be shown. Result: I keep both app on my phone. Widgets I use the old app. Apple Watch, new app.
No need for a tutorial as I have the same problem and I am not sure if its an Apple or Fibaro recent update where the app is on the watch but when you click scenes now the watch has a message that says to "Select scenes using Fibaro for iPhone app" and they are already ticked and were working up until a few weeks ago......so now I guess we play the waiting game until Apple or Fibaro fix the issue.....I am going with Apple that needs to fix the issue
This is not an operating system problem.  No scenes appeared on iOS 12.4 after updating the application on the iPhone.  Technical support Fibaro knows this problem. Unfortunately, it takes a long time and there is no information when they will fix it.  Maybe someone from technical support will speak here?
  • That!, is what I never understand with Fibaro. They have a small dedicated community that actually want them to succeed, and then they totally ignore this sort of question.
    be frank, but most of all, show us that you care.
    Hello Romain,
    Edited by Romain
    Niestety sceny dalej nie działają na Apple Watch mimo najnowszych update. To chyba jednak kwestia po Waszej stronie koledzy z FIBARO. Zadbajcie o nas lepiej niż konkurencja. Nie wystarczy sprzedać i zapomnieć... Liczę na FIBARO, zobaczymy czy przed Gwiazdką naprawią ten denerwujący problem.
    This is really disappointing. How long can such a fix take? Is this company dying? Is it worth investing?
    Same problem here since a few months, not exactly sure when it happened.
    Watch series 5, Please fix ASAP!!
    Same problem here, Apple Watch 5, IOs 13.2.3
    Just installed Fibaros 4.561 Beta with the same result, no scenes appears on the phone
