Problem with FGS223 Double Switch 2 and routing
Moerky
I have a problem with a FGS223 Double Switch 2 not connecting through an other FGS223 Double Switch 2 via ZWAVE protocol to the main switch (number 1). The topology is shown in the picture below. The problem Fibaro has number 44. As it is located far away from number 1 it should route it ZWAVE calls though number 16 which is also a FGS223 Double Switch 2  and far nearer.
How can I achieve this routing? Its useless if I have not a stable connection.
Regards
Markus
 @Moerky in  UI
Try going to Configuration > z-wave Network > Mesh network reconfiguration
Select  the neighbour you want your device to talk too
then press reconfigure.
This will help the device to re access who its neighbours are.
  • Thank you. Which UI are you referring to? If it is Home Center than I must admit I don't have it. I use openhab as a central System to manage everything. What other possibilities do I have?
    Edited by Moerky
