AndreJacomeSilva 0
Hi all,
I've upgraded a couple of my blinds from the Roller Shutter V2 to Roller Shutter v3.
Everything worked properly (after some initial problems) and I did manage to calibrate.
My problem now relies with the association of a FGR-222 button and the Roller Shutter 3 (FGR-223).
As I've done multiple times, I created the association group 2 (assigned to the second switch connected to the FGR-222) to both blinds and additionally I set the parameter 15 to the value 1.
«Parameter No. 15 - Operation of the Dimmer and Roller Shutter Controller - enabling this option allows the user to dim lighting/shut roller by associating Dimmer/Roller Shutter Controller and holding or double press of double switch (only mono-stable switch).
1 - Dimmer/Roller Shutter Controller control is active»
Although this setup works well with the Roller Shutter V2, I cannot have it working with Roller Shutter V3.
Does V3 uses different endpoints?
1 answer to this question
