AndrewFG 0
I am trying to factory reset an FGS-223 unit; according to the manual I should power off, power on, and hold the B-button until the LED turns to Yellow (it says the menu LED should go from Green / Violet / Yellow). However in my case the menu LED goes from Pale Blue / Green / Violet / Green and it never gets to Yellow. So I cannot reset this unit. Is there some other way to reset it?
Note: I cannot reset it via software since it is "paired" with a broken Z-Wave USB stick so I cannot access it or transfer it over the new USB stick without doing a hard reset on it.
