Virtual Device - Scene in a button
pnutp0wer
I integrated my mechanical ventilation system with a RGBW Controller into FIBARO and want to control it by a Virtual Device.
I made a VD with a couple of lines and buttons to set a certain mode for a certain time period.
I added LUA per button but it doesn't seem to work correctly. What I want is that if I press one of the 50% buttons, the ventilation goes this mode for X minutes and than go back to 25%.
When I add "IF" and "THEN" in the button it's not changing to 50%, but if I remove that the time frame does not seem to work.
Anybody who can help me with this? ?
/monthly_2019_10/image.png.02b8c2def3c304442222c7fd073940e0.png" />
6 answers to this question
JFYI:
as I know VS works in locally isolated LUA env. also VD works in its own loop. and last, as I know setTimeOut in VD's (in VD buttons also) works incorrectly.
  • 23 minutes ago, 10der said:
    JFYI:
    Thank you for the reply. What is your suggestion to realize the solution?
    Edited by pnutp0wer
    idk, maybe i will use call scene on click button
    or ... in VD main loop catch button press
    for example on press button set specific lable for iit fibaro:call(selfId, "setProperty", "ui.lblBlaBla.value", "Waiting..."))
    [skipped]
    local deviceState, deviceLastModification = fibaro:get(selfId, "ui.lblBlaBla.value")
    if (os.time() - deviceLastModification) > 60 * 15 then
     fibaro:debug("Yarrrr!")
     fibaro:call(selfId, "setProperty", "ui.llblBlaBla.value", os.date("%Y-%m-%d %H:%M:%S"))
    Edited by 10der
    9 hours ago, Jamie mccrostie said:
    What about just using Fibaro:sleep()
    Sleep freezing thread if it’s ok - sure
    So, what have you done? From my point of view, the best solution would be to use a call scene on the click button, just like  10der@  described above. You would only have to set a specific label for IIT fibaro:call on the press button. For me, it sounds like the best idea. If you found another way to do this, please tell me how you did it. I'm also working on integrating something with an RGBW Controller into FIBARO, and I don't know how to do it correctly. It's a new project for me, and I have to finish it by the end of the following week. We are also working on a website for this project. We've already contacted
    and approached them for their mockups. I hope I'll be able to finish it in time.
    Edited by iurik3d
