rgbw controller and Lua
ggoetz56
Hi
could some explain to me what kind of variable or syntax this command needs
fibaro:call(ID_RGB_CONTROLLER, "setColor", "0", "255", "0", "0")
If i define
local R_value = 255
fibaro:call(ID_RGB_CONTROLLER, "setColor", R_value, "255", "0", "0")
"R_value" is not defined. The command fails.
I tried character and single numeric, global and local etc. or do i have to use a table for all of the 4 values?
I didn't find an example.
Gerhard
9 answers to this question
1) open HC2 UI
2) create empty scene "Add scene in LUA"
3) you can see empty LUA editor
4) move mouse left and make hover on the your room / device RGB device and finally you should see
/monthly_2019_10/image.png.861469561744b34c3eb4e25e0eb8c8ff.png" />
just click on any methods.
FIBARO UI insert methods to your editor.
for example as I can understabd you ask how to set colors independ - yes as you can see setR setG setB what you wish.
good luck!
all R G B W have to be defined - if off then define as "0"
eg
fibaro:call(ID, "setColor", "0","0","0","255")
this sets my strip to White
  • Hi
    many thanks for your response.
    I know the statement "fibaro:call(ID, "setColor", "0","0","0","255")"
    Instead of setColor I can use setValue to change brightness or turnOff to switch off the stripes i.e.
    So far, so good BUT i like to use variables for "Red","Blue",Green","White"
    At the very first moment it seems easy to me to define
    Local Red = "0"
    Local Blue ="255"
    fibaro:call(ID, "setColor", "Red","Blue","Green","White")
    Does NOT work.
    I tried Numeric, String, Array, local global, not at all. I even don't find any hints in the forum
    It seems with
    you store the last "colorset" of your stripes to colorSet i.e. you use "turnOff" to shut down your stripes.
    But how do you restore that? Not with fibaro:call(ID, "setColor",  colorSet)
    So i can't believe no one has ever changed the colorset of RGBW-Module except with use  of fixed values.
    That is achievable.
    I use that myself
    Define the variable
    local red = 232
    local green = 45
    local blue = 55
    local white = 5
    fibaro:call(ID,"setcolor",red,green,blue,white)
    There are no "" around the words so the system knows you are asking for variables
  • @@morpheus75
    That is what i tried first, seems logical to me. But failed.
    @10der
    that's all I get in the Aktion sektion. There is no Set-RGBW.
    I think I got the issue, its the new RGBW2 controller with 500er Chip. I m so lucky.
    Any one has experiences with this module?
    here is the exact code i use:
      local r = math.random(175,255)
      local g = math.random(25,75)
      local b = math.random(25,75)
      local w = math.random(25,75)
      fibaro:call(ID, "setColor", r,g,b,w)
      i have a delivery of the new rgbw2 modules. i will check it when i receive them
  • @morpheus75
    Thanks a lot your great.
    So I have some older RGBW-Module I just tried. They behave well!
    The math.random(x,y) statement means you use a value between (ie r) between 175 and 255 by random?
    You know where to create a support-ticket? My last ticket is about 3 years ago:
    Yes. The random gives me random colours when I turn strips on.
    Support tickets through the fibaro.com website
  • OK Thank you guys very much!
    It will do its job. First of all RGBW2 is different to RGBW. So the commands are different.
    @morpheus75 Your right the type is numeric. I think the issue was i didn't define the White value (I don't need it, but have to define it) in a correct manner. So if w is nil  fibaro:call(ID, "setColor", r,g,b,w) fails without a debug notice even r,g,b  have correct values.
    @10der SetR() does no longer exists. This is a pity  because i have to change only one color, the other colors should stay at their actually given value. And these  values i don't know. I have to read it with fibaro:getValue(id, "color") witch gives me a string like "255,0,255,125" that I have to separate to the single values of r,g,b,w
    Must be something like gmatch() or so.
    Once more thank you for support!
