lua script, doesn,t get triggerd
Thistle
Tried to combine two converted blok scenes to one, but now it wont trigger...
Any suggestions ?
%% autostart
%% properties
%% weather
%% events
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
if (
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "04:00") )
or
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "15:00") )
then
    fibaro:setGlobal("reclameverl", "1");
    fibaro:debug("var reclverl set to 1")
    fibaro:sleep(60*1000)
elseif (
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "09:00") )
or
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "18:00") )
then
    fibaro:setGlobal("reclameverl", "0");
    fibaro:debug("var reclverl set to 0")
I,m hoping someone can give me a hint....
Gary
You have not trigger in scene's header
%% autostart
%% properties
%% weather
%% events
%% globals
What you're trying to do?
Edited by cag014
  • I,m trying to set and unset a variable depending on the time and day
    Edited by Thistle
    In this case you need to loop the scene or you can create virtual device using main loop (is looped by the system)
    To loop scene please use setTimeout() function  see
    Please set "Run Scene" to Automatic as well
    Edited by cag014
  • Thanks a lot, these examples help me a lot
    eventually got it working...
