Communication with raspberry pi as computer
PostarLakogSna
I am wondering if it is possible to connect CO Fibaro sensor directly to raspberry pi? I would like at least to retrieve some signal and process it.
If there is any other way can you point me to it?
Best regards
5 answers to this question
Best regards
no, HC2 has closed software and peripheral devices architecture - your can't connect to USB any own devices and install and develop any softwares.
so. you should configure on rpi for example nginx or light-http-server/ apache and respond via http responce JSON what can hook Hc2 VD, for example
no direct connections to HC2, only Z-wave devices are supported.
otherwise connect your CO device to
Edited by 10der
@PostarLakogSna HC2 it's gray box on your table with label "Home Center 2 / Fibaro system"
most feature HC2 focused on Z-Wave devices and you can't use some user-friendly features from HC2 with third-party devices.
about pushimg notofication
list devices
send push notify
where 192.168.1.36 is HC2
result example (old iwatch 1st gen)
10 minutes ago, PostarLakogSna said:
Thanks for answer, but will co sensor send notification if i dont have hc2?
STOP!
1st you have CO Fibaro sensor
2nd you hav't HC2
3nd you have RPI
yes, you can connect  CO Fibaro sensor to RPI if you have
1)
 shiled
2) or any USB Z-wave sticker. ranging from. UBZ / AEOT to any Chines USB servers
3) also you should have open-sources HA for example HASS / OpenHyb etc
Edited by 10der
