HomeKit + MQTT + Node-RED support for HC2
jack.daniels
Introducing custom firmware for Fibaro Home Center 2 with some extra functions for home automation based on version 4.560.
Changes comparing to stock firmware:
  • Apple HomeKit bridge running (on development stage, not all devices supported yet). Allows to expose all Fibaro connected devices to the Apple Home app. Musthave for iOS users.
  • MQTT bridge running (on development stage). Allows to expose all Fibaro devices to MQTT broker. Musthave for Android users.
  • MQTT broker running. Mosquitto lightwait broker is ready for your tasks.
  • Node-RED running. The IBM IoT platform for home automation.
  • Fibaro Variables panel extended to display/edit string values.
This is custom firmware and not signed with Fibaro keys. You have to enable "ignoreSignature" mode (touch /mnt/nvm/ignoreSignature) in order to flash it on Your HC2 using Fibaro Recovery.
All services are running on boot by default. Configuration performed by Fibaro Variable panel.
Welcome with Your feedback.
  • Like 4
great work!!!!
i only work with android and dont live in the apple universe so i have installed the Fibaro hc2 from 10der in my node-red it works very nice and i connected all my amazon alexa to this devices.
but nice work. I love it if users programming some *abuse* for the community because i dont have the skills iam only a scriptkiddy.
    I understand You very much.
    As much as iOS users love HomeKit as much Android users love MQTT. Thats why there are two separate bridges. Unused bridge could be disabled in configuration global vars
    Btw, there is another packege available now:
    What I am missing in those implementations is user friendly interface. They are too much DIY ;)
    I love to have nodes like this:
    Menu
    In node settings just pick up the device name (filtered by given type)
    Edited by jack.daniels
  • I have checked those two bridges and here is my conclusion:
     - requires inject to work. this is not good, because this way events are handled not immediately
     - on development stage (syntax errors etc.) but it handles events on the go. Bad expiriense with http connection timout faced.
    i want to try your solution but at the moment i dont have much time for this because my family work.....
    1 question if i install your cfw, are there all old scenes modules etc. in my hc2? or is it empty and i have too add all the switches dimmers... new
  • Hi, it is safe to flash this fw, because 99,9% its original content
    The only things modified mentioned in the first post.
    Off-course I would make a backup before ANY manipulation with configured controller to keep all data/setrings safe for emergency, but during my test nothing bad happened
    But my suggestion here: update to 4.560 (in case you still have old firmware) and then use custom fw.
    Hi.
    It is interesting work and I want to use sonoff% MQTT devices with HC.
    But. I'm not very skilled, and stuck with " You have to enable "ignoreSignature" mode (touch /mnt/nvm/ignoreSignature) "
    How should I handle this signature check, Is it needed to be accessed into HC filesystem?
    How?
    Hi, You need to ssh to HC2 user root, password is unique for every device
    If You (still!) not have Yours, I will prepare the guideline for You here
    The MQTT bridge allows to expose fibaro devices to mqtt broker, but not to control other mqtt-connected devices.
    Well, offcourse node-red can translate some dummy property (like user SIPnumber) change to mqtt device control message
    I would sugest to backup before any manipulation on your HC2, but normally all come smooth.
    Here is the root password readout script for HC2 4.560
    You will need python v3 to run it
    Before execute u need to update the script with correct ip address, user and pass
    Menu
    Ok, maybe I’ll implement this idea. Thanks
    Sorry, somethings is not clear for me, what I should re-develop, cuz your proposition like “all sh1t” is not good as for me as for developer of this node.
    Check
     how the polling implemented
    Its should be endless refreshStates loop (timeout 60sec)
    The response will be received right when there are new events posted
    19 minutes ago, jack.daniels said:
    Check
    I am not familar with this node. I am author of
     node and now asking what wrong here.
  • On 11/20/2019 at 10:20 AM, 10der said:
    I am author of
    Yes, I know. I mean, You should check how the polling implemented in other bridge.IMO, events should be triggered when it happen and should not wait for the poll for X seconds.
    yes, Come on, stab! Let's DDOS for HC2!
    that's why I am sking more than 3years from FIBARO put all event into MQTT server.
    well, you shouldnt
    if you look more close to the things I pointed
    fibaro web gui implemented same way
    no ddos at all, the refreshStates waits for event for a minute and returns when there is one
    11 minutes ago, jack.daniels said:
    for a minute
    WUT?!
    second not minute
    and btw I do not totaly understand what you want from my node
