Dimmer 2: No soft start/stop
Kjettern
Hello. I've recently installed 10 fibaro dimmers. All are working well, but one of the dimmers do not start/shutdown with the soft dimming. Is there a parameter to set this? It's not a big deal, but it's quite annoying to watch some of the living room spots light up faster than the rest..
Yes. The soft start can be set in a parameter.
  • Ok so you are referring to parameter 34? Because all my dimmers are set the same, and do the soft start also set the slow shutdown? My other dimmers are fading out when I shut them down, this dimmer only cuts power instantly
