Julegeita 2
Hi!
I have had Netatmo plugin running flawless for 3 years.
2 Days ago, Fibaro suddenly stopped pulling the API.
When I select "get devices" from plugin, nothing happens.
If i try to deactivate and reactivate netatmo account (dev), nothing happens.
But if i restar the HC2, it will pull the correct vaues one time, then stops.
Anyone have a solution to this? Other than deleting plugin and readd it, cause i have alot of lua scenes based on the devices.
Best regards
Chris
5 answers to this question
