Pietgeeroms 0
Hello
I have following issue: my heat controller is installed in a seperate room (on the collector) and the bluetooth controller has not enough reach.
The temperature sensor of the smoke detector is set as main buth the heat controller does not regulate according this temperature but uses its own internal sensor as reference (the storage room temperature).
Is there an easy way if regulating this? I tried thermostat plugin but did not succeed.
Would a seperate thermostat do the job? It's for childrens bedroom so the simpelest will do. Anyone can recommand a type?
Thanks!
4 answers to this question
