lundin 0
Hi!
I have a FGS223 where I connect the mechanical switch inputs directly from the output of two 230V relays (which are controlled by my alarm). The idea is to have my smart home controller to look at the states of these inputs and act accordingly. The outputs are not connected to anything.
I have configured both of the inputs to be "Toggle switch (Persistent positions)" and it works just fine. Until suddently it doesn't....
My problem is that it keeps missing, so when power is on to the switch it reports as off. It worked fine when I set this up and tested it out, but it keeps getting more and more unreliable. I have no reason to suspect my Home Automation controller since I have many devices, including a bunch of Fibaro stuff and it all works well except for this particular device. Any ideas how to work around this?
3 answers to this question
