Check after sleep before action is taken.
Bad33nd
Hi Everyone,
Since a couple of weeks im trying to learn a bit about Lua programming. At the moment im struggling to find an answer to my problem.
To switch floor heating pump i used a power plug on my central heating boiler to measure the power usage to turn on the power of the floor heating pump (also a power plug). First i made a simple block scene which worked fine at first but now i found out that also when im using tap water the central heating boiler is using a significant amount of power. so the idea is to use the living room temp. sensor and the power measurement of the central heating boiler to switch the floor heating pump. Since the margin is very small im trying to do a double check so check if the conditions match, sleep for 3 minutes and check the conditions again before powering off.
This is a bit of the code i used but get a error.
if (PowerCV <'1') and (PompStatus >'1') then
  fibaro:debug('wacht 3 min voor uitschakelen')
  fibaro:sleep(10000)
  fibaro:debug(' 3 min later')
and (PowerCV <'1') and (PompStatus >'1') then
  fibaro:call(191, "turnOff")
  fibaro:debug('Pomp staat nu uit')
it seems like im not able to check another set of conditions after the "sleep". is there a way to do this? all help is appreciated. thank!
Edited by Bad33nd
16 answers to this question
When you write with "if" and "then" the code only runs once.
You need to use "while" and "loop" so the code runs forever.
  • @amilanov  Thanks for your reply. Im having trouble finding examples of the "while" and "loop" functions. I don't know how to implement them. But even wen I run the code multiple times is does not let me recheck the value I guess. is the only way to get this working with more local variables?
    Just write:
    The above will work until the condition [add condition] has been met.
    To get a value of a device use this, replace [add device id here] with the device id = 57
    If the above doesn't help, please explain to me again what you are trying to do and I can write the code for you in its entirety.
    Apologies, I'm a bit busy now, but can help more later if you still need it.
  • @amilanov Thanks for the explanation. However I still think that won't do the trick for me.
    I will try to tell you what im looking for:
    Check power usage of central heating boiler and if power usage is lower than 10W, Wait 3 min. Then Check again if central heating boiler is using less than 10W. if so then turn floor heating pump of, if not end.
    The second check is the problem for me i don't know how this can be done. It is needed since the power usages of the central heating boiler sometimes drops below the 10w for just a few seconds, without the second check it will switch off the pump every time so the  central heating boiler will overheat and turn of and reignite a few minutes later.
    If it it still unclear please let me know so i can rephrase. Thanks for your help!
    I feel bad that I haven't just written the code for you... The problem you are suggesting is very doable.
    I need to know how many times do you want to check that power is less than 10 within the 3 minutes?
    I have assumed every 5 seconds for now ie whets the line shows sleep for 5000 below
    I'm on a phone so writing in semi-pseudo code.
    Where I have written "power" , you need to insert the Fibaro:call to get the power value.
    Local status = 1
    While. status == 1 do
    If power < 10 then
      power_low = true
      While power_low == true do
        fibaro:sleep(5000)
        If power > 10 then power_low = false end
        Power_timer = Power_timer + 5
        If Power_timer > 600 then power_low = pumpoff  Power_timer = 0 end
    If power_low == pumpoff then fibaro:call(pump id, turnoff)  end
    -- if you want to exit the scene here then set "status" to something other than 1 and the scene will end
    Fibaro:sleep(1000)
  • @amilanov Merry Christmas!  Thanks again for your help. I think I'm nearly there however there are some issues with my code. This is what i got at the moment:
    I don't know what im doing wrong but I keep getting a the following error:
    [DEBUG] 14:21:14: 2019-12-24 14:21:14.164166 [ fatal] Unknown exception: /opt/fibaro/scenes/31.lua:39: attempt to perform arithmetic on global 'Power_timer' (a nil value)
    What am I missing?
    Where you have
    Add below it
    I think this will resolve the issue
    I would have thought that you wanted to keep checking the latest value for PowerCV
    Currently you only check update the value once at the top of your code.
    You then have 2x conditions that check PowerCV < 10, the value of PowerCV will never change, from the initial value obtained in the line of code above, once you are in the main loop. You should be checking the latest value below in this line:
    Rather than testing the static variable value of PowerCV.
    EDIT: Are you sure that once the main loop finishes you do not want this code to run again?
    If you want it to run again, then you may want to create an outer while, then, do loop that never stops running.
    Otherwise you will need to keep restarting this scene each time the main loop completes.
    Edited by amilanov
  • Sorry for the late reply, i have added the local power timer as suggested.
    I did not even realise that I was doing this thanks for explaining. I really learned something now.
    However i still have an error that i don't understand. first part of the code runs fine but since it keeps on running it will not restart when power is adjusted and send this error after a few minutes.
    [DEBUG] 20:01:37: 2020-01-02 20:01:37.443546 [ fatal] Unknown exception: /opt/fibaro/scenes/31.lua:47: Assertion failed: Expected string
    this is
     the code now.
    Since "Power 273" is in the properties it will initiate a start when the value of this changes right? or do you suggest another way? Since this is my first lua program im open to suggestions.
    Thanks for your help.
    Having a very quick look at your code, first when you set power low = pumpoff on line 42:
    You need "pumpoff" to be in quotes:
    Also, you need the quotes on line 47:
    I'll check the rest of your code and get back to you if I see anything unusual.
    Edited by amilanov
    Yes, this is a good basic way of triggering the scene. Each time the power changes the scene will run. And you have written the right code here to stop any other scenes from running at the same time:
    You could also set max running instances of the scene = 1
    /monthly_2020_01/Capture.PNG.170b6a733aebd05b96d4ba4761060da6.PNG" />
    From looking at your code, if your intention is to:
    - turn on device = 191 when device = 273 power is >10 and device = 84 is < 25 then the first part works
    - the second part looks to me, barring any syntax errors, to turn off  device = 191 when device = 273 power is below 10 for 300 units which given you have a 5000 millisecond sleep in the while loop, would be after a continuous period of 150 seconds; if this continuous period of 150 seconds isn't reached and power of 273 goes above 10 then you drop out of the loop until power drops to below 10 again, which all looks good.
    I think the only issue you had was when you set power_low = "pumpoff" you need to ensure that it was a string value you where setting. You could alternatively set power_low to a value like 100000 and then test for a value at line 47 below, but I think using a string makes it easier to read, so I would keep it as "pumpoff".
    Well done!
    Yes you could set Max. running instances to 1, but I don't recommend it since it is always possible that first instance still didn't stop running and second start running. Before second scene instance is stopped with that line of code will send you warning that too many instances is running which can be annoying.
    I recommend to always set Max. running instances on greater number than 2 and only use that line of code:
    to terminate any other scene instances. Of course this line of code is recommended to put at the beginning of scene code.
    On 12/10/2019 at 3:38 PM, Bad33nd said:
    Is there no one able to help me out with this? alle help is appreciated..
    Try to use
    no Lua knowledge required and fits your need.
    Thanks for the pickup!
     If I only cared to look at my scenes before posting I would have seen this is what I have done myself.
  • Thanks for the help guys! It looks like we got it working. I'm implanting it now and will test for a few days.
