Range extender for smoke detectors
Erik.rosen
Hi
I try to install a fire/over temp system with Smoke detector.  Half of the detector reach the controller direct but the rest do not......
Today I have Home center lite and 16 smoke sensors FGSD-002
I have relice that battery powered smoke sensor dont transfer Z-wave traffic from neighbours.....
No other units then smoke detectors and a controller is involved at the moment.
Then I try to attach a 230V Fibaro  smart plug into the network as a range extender...
Will this work or do I have to upgrade to Home center 2 and use my HomeCenter lite as range extender
( I think I need at leas 2 extender then the building is with concreate walls and my current controller is centralized..
Will a number of smartplugs solve my problem or do I have to uppgrade to more controller to get this running in a stabile and safe way?
Is there anything in the smartplug configuration I have to take care of or do they work as repeters by automatic ?
Best regards
Erik
1 answer to this question
hi @Erik.rosen,
smart plugs (or any other mains powered z-wave device) will work as extender.
No special setting required.
You can even use the smart plug LED ring to do a range test and see if it reaches your HC Lite.
BR - kro
