FIBARO FGS 221 2*1.5KW V2.1
DomoAutomation
Hello;
I've 2 modules  FIBARO FGS 221 2*1.5KW   V2.1    the modules are new and both cannot accept inclusion or exclusion ... IS there anything  that i should do ?
Your Help is really appreciated
10 answers to this question
Hello @DomoAutomation
Try to exclude and then include, them in the vincinity off the homecenter.
Edited by Flash
  • Before  i do it inclusion i try exclusion ...
    what do you mean  "  in the vincinity off the homecenter" ??  please explain
    thanks
    Basically next to it (distance max. 2m).
    thanks
    à proximité de votre HC
  • I have done the inclusion exclusion in the vivincity of Fibaro HCL its not working ??
    what should i do with those FGS 221 2*1.5 KW??
    it's not working too
    what the solution
    any one facing problem with those FGS 221 2*1.5 KW?
    what the solution
    Do a factory reset the devices. Then try to include again.
    Can take more than one try, for inclusion to start.
    Make sure you in a free line of sight to the Home center and within 2 meters.
  • i'm next to the HCL for 20 cm .
    How i can perform a factory reset on those devices i hop for 14 second? the inclusion button?
    they are new and never broken .. please advice how i can reset them?
    The the
