HC(x) + NODE-RED
10der
2 hours ago, 10der said:
i am not good undestand Sweden :) what sensor type you are use?
@petrho how many Fibari API nodes you are used?
what version (was bug with multi-connections without closing connection to HC)
it’s a fibaro wall plug. I have just one API node (I have also another raspberry with your old package)
version 0.0.17
Edited by petrho
On 1/12/2020 at 1:51 PM, 10der said:
@project
what does the topic reflects here (1590)?
Edited by petrho
  • 8 hours ago, petrho said:
    device ID
    version 0.0.17
    it's my bug :)
    I forgot disable debug messaging
    Do you have a list or examples which commands to use for example dim a dimmer 2 with 30% or how to control the rgw device?  I found that both boolean and turnOn / turnOff work fine for standard relay device...
    Is the recommendation to set API interval to every second or will that affect the HC2 and/or the RPI? Do I still need the reset injection (if yes - why)?
    ...and thanks for a good tool!
    Edited by petrho
    just put integer for dim value
    Sir, as I can undestabd ypu never to see my examples?
    On 1/14/2020 at 8:04 AM, 10der said:
    it's my bug :)
    Is it possible to disable it by myself or do I need an updated version?
  • version:       0.0.18
    added MQTT support
    so now you can setup fibaroAPI node:
    /monthly_2020_01/image.png.f3e3adcff448f300362462c1dcd3e38d.png" />
    than connect MQTT in
    in your HC2 import MQTT VD
    configure
    change the topic
    save VD
    now your HC2 will publish all events to Node-red
    WOW!
    just ignore it.
    events to device should pass once
    Edited by 10der
    thanks for this:
    /monthly_2020_01/image.png.b83f7bcef8eccec5394c7e1fe55c51e9.png" />and this image.png.9c2a9697c226ac18b6d3e0d231980d46.png
    Now is possible transfer the brain of home automation system definitely from HC2 to RPI with mqtt ;-)
    But I preferred old schema of naming topic. In this moment after only 30 minutes test on 0.18 ;-)  but the night is coming ...
    Ex. for device id:610:
    image.png.7a98e03e6b4b9f296a52d705c019457f.png give as topic "home/status/610" in 0.14 but in new (0.18)it's reports topic only as 610
    This give the problem if you use in one flow sensor on direct  devices from two HCx ( with the same ID) without pass via HC API and mgtt in - out for set topic
    Edited by drboss
    Wow - cool with MQTT support in HC.
    However - when I set the FibaroAPI mode to 0 I thought it was disabled. But when I have set to zero and haven't connected mqtt node to in - it sends data via the out pin
    Edited by petrho
    and I receiving from fibaroAPI many error message in debug (if debug off, too) like:
    /monthly_2020_01/image.png.5f838008d9f68f2680f7c44f3ca4fdec.png" />
    Small modification of VD, pause/restart query to mqtt server, and like in orginal it's good to create global variable MQTTBox before first run.
  • simple MQTT IN
    @drbosswelcome for fixes
    change topic + callback action
    /monthly_2020_01/image.png.4274a64ee99a350ef440c167e7807e63.png" />
    @10der small question because I'm not specialist of node-red programming but if possible that You add to "fibaroSensor" place for topic (of course this is low priority ask):
    /monthly_2020_01/image.png.64d92ea861dc5faf6a69b91a925fd8dc.png" />
    this useful if we use fibaroSensor without VD for get the result like  "/HC-001010/502 : msg : Object" in place of "502 : msg.payload : Object".
    ps. After night with HC2 and node-red I say ... you work is very impressive, THANKS. It give second live to my HC2. With RPI zigbee and 433 RMpro I'm sure than now I'm not interested to bay HC3 (very secured -> restricted model :-( ) for my house.
    and small modification for last VD MQTT_Handler, line 238:
    Edited by drboss
    After migration to 0.18 what can I do for thermostat?
    1. I create fibaroXActor with Actions like this:
    and my question what I need to send in injection to this Actor to work?
  • Please login or register to see this code.
    as string
    IMHO
