10der
MQTT client, Fibaro I love you! (not!)
/monthly_2020_01/image.png.256a2290f63eac6557f98b74d4537ac3.png" />
source (VD)
Edited by 10der
  • Like 4
Share this post
Link to post
  • simpel VD.
    can send all fibaro evenets to MQTT server
    limitation loop 2 sec
    Share this post
    Link to post
    For past command to mqtt from hc2 (before your nodes didn;t support via FIbaroSensor scenes triggers from ex. pilots, keyfob etc) I used "http-in" endpoint
    /monthly_2020_01/image.png.b91c90af392df9a0af372607432da857.png" /> and in fibaro scene the code like this:
    Off-course  after small modif fot http call it work from VD.
    It not professional like  @10der code but works too ;-)
    Edited by drboss
    Share this post
    Link to post
  • can receive MQTT messages
    Share this post
    Link to post
    Could you explain the VD code with an example?
    Many thanks
    Share this post
    Link to post
    @10der, great - thnx! you saved me a lot of time!
    Only global value to add and it works superb!
    One question, how to use user/pass? I can see in flags, but how to pass it?
    t
    Share this post
    Link to post
  • alas. no auth in HC2 MQTT
    Share this post
    Link to post
