HC2: MQTT client, Fibaro I love you! (not!)
10der
/monthly_2020_01/image.png.256a2290f63eac6557f98b74d4537ac3.png" />
source (VD)
Edited by 10der
  • Like 4
  • simpel VD.
    can send all fibaro evenets to MQTT server
    limitation loop 2 sec
    For past command to mqtt from hc2 (before your nodes didn;t support via FIbaroSensor scenes triggers from ex. pilots, keyfob etc) I used "http-in" endpoint
    /monthly_2020_01/image.png.b91c90af392df9a0af372607432da857.png" /> and in fibaro scene the code like this:
    Off-course  after small modif fot http call it work from VD.
    It not professional like  @10der code but works too ;-)
    Edited by drboss
  • can receive MQTT messages
    • 2 months later...
    Could you explain the VD code with an example?
    Many thanks
    • 1 month later...
    @10der, great - thnx! you saved me a lot of time!
    Only global value to add and it works superb!
    One question, how to use user/pass? I can see in flags, but how to pass it?
    t
  • alas. no auth in HC2 MQTT
    • 1 month later...
    Thank you soooo much
    With the help of your handler I am now able to receive MQTT messages.
    Thank YOU so much :-)
    I use it to receive messages from a WeatherFlow weatherstation on the local network!!
    NO more internet connection needed!!!
    After months of struggling to receive something from the Weatherflow via local UDP broadcast ( which I could not get to work and might even be disabled in HC!!! )
    I can now receive the messages via MQTT ??
    I used an already running Raspberry Pi ( running Dietpi) and copied a the Python script "
      " from here:
    and followed the instruction on that site!!
    • 4 months later...
    W dniu 15.01.2020 o 21:44, 10der napisał:
    simpel VD.
    Small update to MQTTSend.
    Without this update MQTTSend throws error when MQTT broker goes down (so finally does not reconnect after MQTT goes up).
    function MQTTSend(msg)
    -- fibaro:debug(msg)
    if not connection then
    connection = connect(fibaro:get(fibaro:getSelfId(), "IPAddress"), fibaro:get(fibaro:getSelfId(), "TCPPort"))
    if connection then
    bytes, errorCode = publish(connection, MQTT_TOPIC .. "/connection", "Connected")
    bytes, errorCode = publish(connection, MQTT_TOPIC, msg)
    if errorCode > 0 then
    connect_close(connection)
    connection = nil
    -- connect_close(connection)
    • 10der changed the title to HC2: MQTT client, Fibaro I love you! (not!)
    • 1 year later...
    Hi, would need some guiding how to use HC2 and this MQTT_Handler to get data from an Solar inverter Ferroamp.
    Really hope someone could bring some light for me in this topic :-)
    • 5 months later...
    I´m trying to recive an quite large MQTT message via this script shared in this topic.
    But I have no succes with that.
    Via this command in script:   local response, errorCode = connection:read()
    The message ends up in the response variable but that variable get limitet at 1024 byte so whole message wont fit.
    Is it and limitation in HC2 about varible size or is it any way to declare it larger?
    In the MQTT message a get at remaining lenght the value 2056.
    Where to find documentation for use of tcpSocket = Net.FTcpSocket(hostname, port)?
    What are all available commands/methods and could it be one for set of maximum buffer size?
    tcpSocket:setReadTimeout(###)
    tcpSocket:write(msg);
    tcpSocket:read(msg);
    tcpSocket:disconnect();
    • 2 months later...
    @pflugj Can you please explain the basics of how you got the MQTT receiver working?
    Is there a Global Variable that is needed?
    Do you have to set the IP address field in the VD?
    Thanks for your help,
    G.
    Edited by clowg
    • 1 month later...
    Hi
    I just followed the instructions on:
    ...and you have to set the IP address in the VD
    Best regards
    Jurgen
    • 4 months later...
    I am able to establish a connection :) using your VD. Now, how the get individual values from MQTT?
    thank you
