dannykay 2
I have an RGBW 441 where I am using only the W channel to light a room, with the momentary switch connected to the IN4. It appears that the current power consumption works correctly after removing the device and adding it but then after a certain time it gets stuck at a certain value and will not change whether the device is on or off. It shows for example 106.5 W no matter if you turn it on, off or dim it. Sometimes this value will change to 0 or another number but I am not sure how. you must remove the re-add the device for it to work properly(report correct power consumption) for a while. Other than this wrong reading, the device functions as expected. Any ideas what is causing it? BTW the device is on its latest firmware 27.27, HC2 version 4.570, , soft reconfigure does nothing . Any ideas?
/monthly_2020_01/gav.jpg.f2141749de0d0aa443a9e347a97a3807.jpg" /> Edited by dannykayLink to comment
3 answers to this question
