vidarsolli 0
I have two Fibaro installations (HC Lite 4.570) and I am planning a third. In all houses I have installed Google Home. Integrating the first Google Home with Fibaro went well and I am able to control switches via Google Home. Then I went to the other house and set up the Fibaro system. The same Fibro ID is set up to control both. I initially had the same log-in credentials on both systems. When trying to integrate the Fibaro installation in Google Home, only the devices from the first Fibaro installation were available. Any one having an idea on how to solve this, how to control several Fibaro installations with Google Home? Is it a bug at the Fibaro side?
4 answers to this question
