Note, this method is replaced by using HTTP instead of api.get. See ex.     Another thing that can be useful to do in QD's is to receive triggers - because scenes are so "functionality challenged" in the HC3 it can be useful to use QD's as scenes and let them react on events in the systems. Here is the standard way of polling /refreshStates and then posting the incoming events to a user defined QuickApp:event(event)   Please login or register to see this code. There could
    2
