jgab
Nvm my previous comment.. the problem was on my side :)
Now it crashes when trying to get the json from the Http:
Edited by Momos
    Can you post the whole code?
    Oh, if you used my last example you should use http:request, not self.http:request...
    5 hours ago, jgab said:
    Ok, the 3rd method, and a bit more "object oriented" in style,  is to delegate the actions to the children themselves.
    The idea is that you send all the data you collected to all the children, and each child picks out the data relevant for it and uses that to update whatever.
    Here we define a method :updateValue for all children that we call. Then we don't need to know their names - they know what to do with the data...
    I haven't been able to test it but at least it compiles :-)
    Thanks @jgab ! I like this method. Without the child devices I thought about creating a separate QuickApp for each reading (temperature, humidity, pm2.5 and pm10). But then I had four the same sources, that didn't make any sense. So the child devices are a great solution! The effect is somewhat similar to for instance my out of the box MCO Home CO2 sensor.
    I would probably do the loop like below. Then you can keep 'ipaddress' etc as local lua variables and don't need to read them in every time in the loop.
    ...and you are not using the 'otherData' field so I removed that too.
    It was kind of a mess, thanks. I think I go further with it for instance the part where the labels get their values. I also have to make the variables a bit more foolproof. If the variables aren't there, then create them. Etc.
    This is really great. At first I thought the child devices where a bit too complicated for me, but it ain't that difficult (with some help ?) and they add a lot of new possibilities. ???
    And I now can see the values in the mobile app. That is nice for a change ?
    Edited by SmartHomeEddy
    Hehe i got that from reading the manual :)
    So it looks like i almost got it working for my sensor but for a few minor details.  It crashes with "operation cancelled" and does not seem to want to update witht the set interval...
    Cheers @jgab and @SmartHomeEddy for this QA :)
    Log:
    Sometimes I get the same error. I assume that is the case when the sensor doesn't give an answer within the 3 seconds of the http request.
    If that is the case. I wouldn't worry. But if you enter a wrong IP address or path, you get the same error.
    The IP is correct as the API call has a response.  Typing in Chrome the url always gets an answer.
    However the QA log :
    Modifying something and saving works... and all the sensors are updated... ?
    Edited by Momos
  • If it times out it calls the error handler.
    I would suspect that it calls the success handler but with a code saying that the operation was cancelled - can you check the status code when it crashes?
    Because then you will not have any .data field and the json decode etc will crash,
  • Define this function
    and then in your http request
    It will catch errors in the handlers and report them.
    Because it seems like errors are not always reported well when callbacks and setTimeout functions crash.
    either i don't know where exactly to insert those into the Http request, or it does nothing.  I think it is the first ?
    It does not like ??
    Ha !  i found out what the heck is going on..
    I modified
    to
    and
    to
    All works now and sensors are updated as per Interval.
    It seems these last lines of self:debug were introducing the error.
    I confirm it works also with the first version i posted if i change these last few lines.
    Cheers again @jgab and @SmartHomeEddy . Happy now to have my Urad sensor in HC3 :)
    Edited by Momos
    IF I comment out these last self:debug lines... i get again the error "operation cancelled"
    Weird :)
    Sorry I missed the rest/response thing.
    Yes, the values were put in a table named 'data'.
    The last problem is weird but shouldn't be related to your debug statements....
    I am getting better at this :)
    I created a QA for my power meter and it works well.
    I left however the childs class as com.fibaro.multilevelSensor as i had no ideea if there is a class like com.fibaro.powerMeter ... Is there one like that ?
    The reason why i ask is that i would like to have the history of these devices in HC3.. somewhere..
    Edited by Momos
    There is a type energy meter.
    I insert the power usage not by my Fibaro devices in a unused device. So I have all power usage in my Homecenter. Now waiting for a fine energy panel on the HC3.
    Yes
    I measure the power consumption of all devices and deduct it from the total power consumption. I put the difference in a unused device.
    cool:)
    I see that the child devices have a "value" .  Can one child device store 2 values for example: "value" and "power" ?
    here is where i need to modify it  please?
    local initChildData = { -- Just my own local table to be able to make a loop - you may get your initial data elsewhere...
          {className="Phase1", name="Phase1", type="com.fibaro.multilevelSensor", value=0, unit="Watt"},
          {className="Phase2", name="Phase2", type="com.fibaro.multilevelSensor", value=0, unit="Watt"},
          {className="Phase3", name="Phase3", type="com.fibaro.multilevelSensor", value=0, unit="Watt"},
    Haven’t done that yet, but I think the property should be “power”
    Because I put the power usage in that property with
    hehe i think i learned something... then i want to improve and i break it ??
    I deleted the QA to recreate it as energy meter, not multilevel sensor, so it shows in history.
    But now the values are gone from the child devices...
    /monthly_2020_07/image.png.148d18b9de51cb562429edef76e874b1.png" />
    they are still in the labels of the main device
