jgab
  • 14 minutes ago, Martin_N said:
    @SmartHomeEddy
    The reason will probably be server overload. Because you have a timeout (HTTPclient) of 5000ms, you will get an error message. If I tested it on a question, in several cases I received an answer after 30 seconds.
    Maybe try to replace  your self:debug("beep") to self:debug("response status:", response.status). See if you get any codes other than 200.
    I get beeps every ~120s, lower than that and I get timeouts.
    Thanks @Martin_N
    I only get 200
    Yes @jgab
    If I put the http = net.HTTPClient({timeout=120000}) indeed, no errors.
    So the conclusion is, the site takes more time.
    Running some test with the http = net.HTTPClient({timeout=N}) setting. 60*1000 give some errors. 90*1000 minor amount error. 10*1000 no errors. But I think it will depend on the time if day en behavour of the site.
    Now I know it isn’t the code.
    Thanks ? !
  • In my QA_Toolbox (v0.17) there is a new module for publish/subscribe.
    Publish/subscribe makes it possible for QAs to communicate with each other without having to know each others' names or deviceIDs.
    QAs  subscribe to the messages they want to receive.
    ...and QAs publish events - and the events are automatically picked up by the QAs that subscribe to them.
    Events will not be sent to QAs that doesn't subscribe to them and the subscribe filter can be quite advanced.
    It consist of two function
    events are Lua tables with at least a type file. Ex. {type='myEvent', value=42}
    (It's the same structure as sourceTriggers have - and the Toolbox module 'triggers' fetches refreshStates events and repost them as sourceTriggers for the QA.)
    event-patterns that are subscribed to can be partial. That means that
    event.pattern {type='myEvent'} matches {type='myEvent', value=42}
    but event.pattern {type='myEvent', value=42} does not matches {type='myEvent'}
    If module "events" is loaded the patterns can also have constraints.
    event.pattern {type='myEvent', value='$>41'} matches {type='myEvent', value=42} but not  {type='myEvent', value=40}, and it also states the an event needs a 'value field.
    Ex.
    You will never receive your own 'posts' even if you subscribe to the events you post.
    To be able to do something with incoming events you need to register an eventHandler.
    If you load the Toolbox module 'events' it automatically register a handler for it's rules and you can write
    but you can also add your own custom handler
    It plays well together with the 'triggers' and 'events' module allowing you to have a common event stream for HC3 triggers (sourceTriggers from devices etc), local events used by the QA internally, and events from other QAs. It's also the same base I use for
    - so I do eat my own dog food ;-)
    another one lib ported to HC3:  sha2.lua from Egor Skriptunoff
    Support for: MD5, HMAC, SHA-1, SHA-224, SHA-256, SHA-512/224, SHA-512/256, SHA-384, SHA-512, SHA3-224, SHA3-256, SHA3-384, SHA3-512, SHAKE128, SHAKE256
    I removed everything not necessary on HC3, leaved only INT64 (works best), LIB32 (slower but less CPU load) and bit lib emulation (for testing).
    Examples, FAQ and Benchmark included.
    Hashing speed (Bytes per Second) on Fibaro HC3, so there is definitely (bit) difference ^^
    Edited by tinman
    • Like 5
    Inspired by the code in the sha2 lib, i updated the aeelib (which i posted before somewhere in this topic)
    Support for: AES128 / AES192 / AES256 ->  ECB, CBC, OFB, CFB, CTR modes
    Now it works something like 77 times faster than before, so i'm happy now.
    Changed bit syntax and examples as well.
    function aeslib.decryptString(key, data, modeFunction, iv)
    function aeslib.encryptString(key, data, modeFunction, iv)
    Edited by tinman
    • Like 4
    Is anyone have tried to change QA global variables using api.put() or api.post() methods?
    Looks like it's blocked by system!?
    Have tried to post the data, no success.
    qData={value={{name="Test",value="value"},{name="myVar",value="10"}},modified=1597468789}
    api.post("/devices/78/properties/quickAppVariables",qData)
    Any idea?
    Any idea?
    accordint to sorces from Jan
    self:updateProperty('quickAppVariables'self.properties.quickAppVariables)
    I'm looking to update variables from other QA or scene.
    Looks like that should work, but still no success
    qData={properties= {quickAppVariables= {{name="Test", value= "900"}, {name= "myVar", value= "10"}}}}
    api.post("/devices/78",qData)
    OK, it works... my mistake should use PUT method
    api.put("/devices/78",qData)
    I am struggling with updating and deleting global variables. This is the function to put json data in some global variables:
    This is how I call the function (one example, more than one Global Variable):
    This is how the function looks like:
    If they don't exist I get:
    What looks OK
    But if I try to update them, I get
    (HTTP Status Code 400: The server could not understand the request due to invalid syntax.)
    The Global Variables does get updated.
    And if I try to delete them, I get:
    (HTTP Status Code 404: The server could not understand the request due to invalid syntax.)
    And the Global Variables don't get deleted.
    Apparently I am struggling when to put and when to post.
    I am doing it all wrong, but what?
    Edited by SmartHomeEddy
  • To get a variable do
    api.get("/globalVariables/"..name)
    if it doesn't exists you get nil otherwise you get a table {name=..., value=..., }
    To create a variable do
    api.post("/globalVariables",{name=..., value..., ...})
    'value' must be string. There are more keys like readOnly etc... but they default to false.
    To modify an existing variable
    api.put("/globalVariables/"...name,{value=...})
    value must be string
  • Here is an "enhanced" fibaro.setGlobalVariable with an optional flag to create the variable if it doesn't exist
    Bug - and check if global is deleted
    When do I put a / behind the globalVariables ?
    Always for get, post, put and delete, or in case of a post not?
    The REST API basic knowledges ;)
    I am confused, according to Swagger alway with get, put, delete. But according to @jgab not in a post.
    And I am doing something wrong
    Before
    After
