jgab
  • 1 hour ago, michal85pl said:
    changed but still 0%
    Do you get any log on the HC3 that like "multilevel sensor <id> batteryLevel=<x>." ?
    Nope..
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",1],"deviceId":397}
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: binary sensor 8 value=1
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",0],"deviceId":398}
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: binary sensor 17 value=0
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",0],"deviceId":400}
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: binary switch 14 value=0
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",0],"deviceId":399}
    [10.09.2020] [08:23:05] [DEBUG] [QUICKAPP368]: binary sensor 10 value=0
    [10.09.2020] [08:23:25] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",0],"deviceId":397}
    [10.09.2020] [08:23:25] [DEBUG] [QUICKAPP368]: binary sensor 8 value=0
    [10.09.2020] [08:25:47] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",0],"deviceId":398}
    [10.09.2020] [08:25:47] [DEBUG] [QUICKAPP368]: binary sensor 17 value=0
    [10.09.2020] [08:25:47] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",122],"deviceId":399}
    [10.09.2020] [08:25:47] [DEBUG] [QUICKAPP368]: binary sensor 10 value=122
    [10.09.2020] [08:25:48] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",22.3],"deviceId":401}
    [10.09.2020] [08:25:48] [DEBUG] [QUICKAPP368]: binary sensor 9 value=22.3
    [10.09.2020] [08:25:48] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",1],"deviceId":397}
    [10.09.2020] [08:25:48] [DEBUG] [QUICKAPP368]: binary sensor 8 value=1
    [10.09.2020] [08:25:48] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",0],"deviceId":400}
    [10.09.2020] [08:25:48] [DEBUG] [QUICKAPP368]: binary switch 14 value=0
    [10.09.2020] [08:26:29] [DEBUG] [QUICKAPP368]: onAction: {"actionName":"setProperty","args":["value",22.8],"deviceId":401}
    [10.09.2020] [08:26:29] [DEBUG] [QUICKAPP368]: binary sensor 9 value=22.8
  • 55 minutes ago, michal85pl said:
    Nope..
    at around line ~320, change
    to
    Here is a new version with the fix. (1,6)
    to
    With new version (all credenetials set):
    [10.09.2020] [17:33:00] [ERROR] [QUICKAPP368]: QuickApp crashed
    [10.09.2020] [17:33:00] [ERROR] [QUICKAPP368]: main.lua:350: Missing credentials. Setup quickVars IP,User,Pwd
    I didn't check the old one with changing the above code.
    without this:
    HC2_IP   = self.config["IP"]
    HC2_USER = self.config['User']
    HC2_PWD  = self.config['Pwd']
    assert(HC2_IP and HC2_USER and HC2_PWD,"Missing credentials. Setup quickVars IP,User,Pwd")
    QA runs, read battery, but still 0%
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: binary switch 14 value=false
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: binary switch 14 batteryLevel=94
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: Call HC2:http://192.168.20.4/api/devices/9
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: binary sensor 9 value=24.80
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: binary sensor 9 batteryLevel=100
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: Call HC2:http://192.168.20.4/api/devices/8
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: binary sensor 8 value=false
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: binary sensor 8 batteryLevel=100
    [10.09.2020] [17:41:32] [DEBUG] [QUICKAPP368]: Call HC2:http://192.168.20.4/api/devices/17
    [10.09.2020] [17:41:33] [DEBUG] [QUICKAPP368]: binary sensor 17 value=false
    [10.09.2020] [17:41:33] [DEBUG] [QUICKAPP368]: binary sensor 17 batteryLevel=100
    [10.09.2020] [17:41:33] [DEBUG] [QUICKAPP368]: Call HC2:http://192.168.20.4/api/devices/10
    [10.09.2020] [17:41:33] [DEBUG] [QUICKAPP368]: binary sensor 10 value=129.00
    [10.09.2020] [17:41:33] [DEBUG] [QUICKAPP368]: binary sensor 10 batteryLevel=100
  • 14 hours ago, michal85pl said:
    without this:
    I moved the credentials to be set in the QA's quickAppVariables tab.
    So it reads the battery - progress! :-)
    however, I still had a bug. Here is a new version.
  • 15 hours ago, michal85pl said:
    Is that for all your devices?
    Do you get a log like "binary switch 146 batteryLevel=60" ?
    When I try I get a
    /monthly_2020_09/batt.png.ed0a24e063c04e0421d85402a8bb46ac.png" />
    I have also empty batteries on motion sensor, D/W sensor and battery powered rollerSchutters...
    When I try I get a
    [12.09.2020] [10:08:21] [TRACE] [QUICKAPP415]: Scene ID for HC3Proxy is 1
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/8
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 8 value=false
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 8 batteryLevel=100
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/9
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 9 value=22.20
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 9 batteryLevel=100
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/10
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 10 value=231.00
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 10 batteryLevel=100
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/14
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary switch 14 value=false
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary switch 14 batteryLevel=94
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/17
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 17 value=false
    [12.09.2020] [10:08:21] [DEBUG] [QUICKAPP415]: binary sensor 17 batteryLevel=100
    Additional suggestion, if You moved credentials to QA's quickAppVariables tab., maybe it would be more convenient to move HC2 scene ID  there too?
    Are you running v1.7?
    I attached v1.8 that has a bit improved logging.
    The HC2 scene ID is auto discovered and should not be set in the code.
    All config for the HC2 is via the quickAppVariables now.
    More lengthy configs like the device mapping is unfortunately not very convenient to add via quickAppVariables (there is a quite limited length of the value field)
    Still 0% (should i paste anything more than main file code?), does this error mean something?Should it be that after removing child devices a restart of QA is required to reinstall them or is this a bug?
    HC2ID is autodiscovered now :)
    [12.09.2020] [10:36:53] [ERROR] [QUICKAPP415]: %s - %s
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: QA HC2Proxy - version:1.8 (QA toolbox 0.18)
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: DeviceId..:415
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Type......:com.fibaro.binarySwitch
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Interfaces:["light","quickApp"]
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Room......:228
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Visible...:true
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Created...:Fri Sep 11 23:51:21 2020
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Modified..:Fri Sep 11 23:51:21 2020
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Setup: Event manager (0.2)
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: Setup: Child device manager (0.3)
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: 5 children
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: onAction: {"args":["value",0],"deviceId":436,"actionName":"setProperty"}
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: binary sensor 17 value=false
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: onAction: {"args":["value",0],"deviceId":435,"actionName":"setProperty"}
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: binary switch 14 value=false
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: onAction: {"args":["value",23.3],"deviceId":433,"actionName":"setProperty"}
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: binary sensor 9 value=23.3
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: onAction: {"args":["value",231],"deviceId":434,"actionName":"setProperty"}
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: binary sensor 10 value=231
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: onAction: {"args":["value",0],"deviceId":432,"actionName":"setProperty"}
    [12.09.2020] [10:37:00] [DEBUG] [QUICKAPP415]: binary sensor 8 value=false
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/scenes
    [12.09.2020] [10:37:01] [TRACE] [QUICKAPP415]: Scene ID for HC3Proxy is 1
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/8
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 8 value=false
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 8 batteryLevel=100
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/9
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 9 value=23.30
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 9 batteryLevel=100
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/10
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 10 value=231.00
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 10 batteryLevel=100
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/14
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary switch 14 value=false
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary switch 14 batteryLevel=94
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: Call HC2:http://192.168.20.4/api/devices/17
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 17 value=false
    [12.09.2020] [10:37:01] [DEBUG] [QUICKAPP415]: binary sensor 17 batteryLevel=100
    [12.09.2020] [10:37:40] [DEBUG] [QUICKAPP415]: onAction: {"args":["value",1],"deviceId":432,"actionName":"setProperty"}
    [12.09.2020] [10:37:40] [DEBUG] [QUICKAPP415]: binary sensor 8 value=true
    I have also correct battery levels reported in the logging, but displayed as 0% :-(
    [12.09.2020] [11:01:57] [DEBUG] [QUICKAPP802]: Call HC2:http://10.0.0.50/api/devices/1173
    [12.09.2020] [11:01:57] [DEBUG] [QUICKAPP802]: multilevel switch 1173 value=40
    [12.09.2020] [11:01:57] [DEBUG] [QUICKAPP802]: multilevel switch 1173 batteryLevel=100
    Edited by Bodyart
    This is magic....
    Can you do me a favour, edit your current QA and around line ~280 there is main() defined, add in the beginning:
    where you change the 1374 to the HC3 id of a childDevice that has battery value 0% - and see if it gets updated to 77%
    /monthly_2020_09/afbeelding.png.b6db377020af8c3456537f4b82958845.png" />
    yeapp
    I've outremarked that line again but the battery level stays on 77% :-D
    Edited by Bodyart
  • 9 minutes ago, Bodyart said:
    yeapp
    Ok, one more test. Around line ~150 there is the function (for multilevelSwitch) that updates the battery property and logs the
    "multilevel switch 1173 batteryLevel=100"
    Could it be that the property value arrives as a string?
    Can you add a tonumber around the value argument? (and 'or value' in case it's not a number)
    Like
    Like
    I see you use it for rollerShutter - I think we could do a childDevice class that fits better the rollerShutter and makes the buttons working.
    Y E S !!!
    That fixed it, happy now :-D
    Probably we need to change the other updateProperty occurencies, because my Motion sensor and D/W sensor also show zero battery.
  • 5 minutes ago, Bodyart said:
    Y E S !!!
    Ok, here is v1.9 with the fix
    • Thanks 2
    I have changed also other occurencies and now having all batteries displayed :-D
    Edited by Bodyart
