jgab
1 hour ago, Krikroff said:
Hum... Strange.
i will try to reproduce when sonos are not available on network.
have you any problems with wifi ?
I solved a similar problem with my QA for iEast player.
My conclusion is that workload problems are caused
1) communication failures on w-fi between devices (HC3 - audio)
2) HC3 - LAN communication outages
3) occasional mental problems HC3 own when you can not even save any parameter and the end of a 500/501 Internal Server Error
2 hours ago, Krikroff said:
Hum... Strange.
No I have no problems with wifi. At this moment only 5 Sonos players (not playing now), 2 camera's and an iPhone are using wifi (without problems). I deleted one of the two Sonos ZC QA's.
I rebooted the Orbi RBR50 router and the CPU load of the HC3 at the time of this reboot is:
I see from time to time a very short time error message at the bottom site, I saw the word "Error" and also "EOF" if I am not mistaken, all in red color.
Could it help to activate a sort of debug mode?
Edited by Rover
There is clearly a communication fault between the HC3 and the network...
Is it possible that the Orbi RBR50 is blocking requests for some reason (ex: excessive polling) ? You also had a network access problem with the QA offered by @10der, didn't you?
Workaround in the next version, I can consider the possibility of completely interrupting the polling for a given time in the event of faulty communication between the HC3 and SONOS devices
I do not think it is a network problem of the HC3. I checked in the log and rebooted the router: no difference.
Why is this excessive CPU load only present when Sonos ZC is active?
There was no network problem using @10der's Sonos_Hub, only a problem with the json encoding of the call parameters, what has been solved with help of @cag014.
I have set the Sonos ZC debug mode on:
Edited by Rover
Hi All,
A quick question please:  I have a weather station data imported via MQTT to a QA with child devices, one child for each sensor.  In the labels of the QA the temperature shows correctly with the - sign.
/monthly_2020_11/image.png.ff231357e1d14cdba3924cca4033c2ad.png" />
However, in the corresponding child the - sign does not show.
I am updating the data to the child device with :
self:updateProperty("value",(data.temperature))
The debug shows it  being a negative number.
Any idea please ?
Thank you
9 hours ago, Momos said:
Any idea please ?
search post on the forum by @afendikovwith subj "fibaro be carriful with rounding float values" :)
Fibaro... it's fibaro.
  • Someone asked for a simple example for a write/read to a socket. Som devices has simple text based protocols over sockets to control them.
    This example is similar to the Fibaro TCPSocket example but maybe a bit simpler. This also creates new sockets for each requests (sockets can't be reused after closed, so it requires some extra code to keep a socket alive as long as possible and still cater for errors)
    Gaahh ... i have nothing more to say
    ahaha ??  My response was targeted at Fibaro ?  I can not belive such a thing can actually exist in a device nowadays.  Especially in one with a high price tag.
    Edited by Momos
    How to change size and color of text in self:updateView?
    How to change background color of QA buttons?
    People have managed to put HTML tags in the label text. It may not work in all browsers/apps.
    In Edge as well as Firefox self:updateView("btn_SPH", "text", "<font color=#fd7e14>Setpoint Hoog) shows in the button: font color=#fd7e14>Setpoint Hoog
    Labels it works for, buttons no.
    So string formatting or color change of buttons is always a nogo?
  • Well, it's possible if you hack the viewLayout property yourself.
    The problem is that the UI can't be edited in the HC3 Web editor anymore. In fact, if you just re-save the QA the viewLayout is "reset". So I would say that's it not really that useful until Fibaro starts to support better layouts.
    I do all my coding offline in ZBS and the UI spec allows me to add funky UI layouts if I need (but I usually don't)
    /monthly_2020_12/labels.png.33ceb04c7f804388f89e962da68e5e85.png" />
    using the code
    Here is a even more interesting QA with pop-ups etc.
    • 3 weeks later...
    On 4/19/2020 at 6:28 PM, jgab said:
    There have been posts about getting triggers/events in QAs using the /refresStates API.
    This post is nothing new but wraps the logic in a 'SourceTrigger' class
    If we have this class we can use it like this
    The functions we define on SourceTrigger has the name <type>_<property>
    will be called with 'source triggers' of type {type='device', property='value' ...}
    If we define
    we will get all triggers of type {type='device', ...}
    For triggers without a 'property' field we only have the type.
    The intention is that the triggers should look like the sourceTriggers available for Scenes.
    If we need different trigger loops we can subclass 'SourceTrigger'
    Dear all,
    first of all, thanks for this excellent post. I migrated all of my HC2 stuff to HC3 with basically just this thread as a reference. Kudos to @jgab@petergebruers and all the other folks.
    I have some QAs working as MQTT subscribers, 528 and 542. The publisher sends a single update, so two QAs get updated at the same time. The update of 528 triggers the update of another QA (535). These QAs are updated correctly. But the SourceTrigger QA from the post on page 17 gives:
    I don't understand why 542 or 528 are missed most of the time. Two events that happen at the same time should be caught by
    Is this some crazy race condition? Maybe not, because setTimeout on self:updateProperty in 528 does not really help missed triggers. And it is not a nice solution.
    Do you have any futher suggestions how to tackle this problem?
    Cheers, jayrock
  • 2 hours ago, jayrock said:
    Dear all,
    Cheers, jayrock
    If you update the property of a QA (ex. the value property) it will only generate an internal trigger (event) if the value differs from the current value.
    Ex. self:updateProperty("value",fibaro.getValue(self.id,"value")) will not generate a trigger.
    Also, do your MQTT send events if the value changes or with regular intervals?
    Thanks, that makes a lot of sense. Indeed the value does't change that often. It also explains why some sensors seemed to work "better".
    Yes, the devices do send on regular intervals, that means they send an update (which can be observed via MQTT) even if the value hasn't changed.
    Let me do some more monitoring and see if this is the explanation.
    Cheers,
    jayrock
    Edited by jayrock
