jgab
Hi JGAB,
I have finished to modify your QA SVGTest2.fqa with my 4 floors, Temperatures displayed in each room with update every 1.5mn, each lights status On (enlarge red indicator) or Off (small green indicator) for each room with update every 1s.
I want to have the first row of buttons beeing hidden or visible by changing a quickAppVar "Grid"=false or true.
The question is there an attribute in the line
--%%u={{button='raster',text='Grille',onReleased='raster'},{button="sensors", text="Couleurs", onReleased="indicLamp"}}
which can make the buttons visible or hidden (I think the QA needs to restart)?
Do I have to change it with a QA property change?
if it is the case, will code be the same in vscode and HC3 QA?
The reason is that the raster is not needed in a normal running QA but for any change in the number of devices, raster is mandatory to place then on the picture (I spend a full day for doing it with 9+15+16+9 lights and 6+9+12+4 temp sensors)
Again these changes will have not been possible without fibemu ( Thanks🤩)
which can make the buttons visible or hidden (I think the QA needs to restar)
I have found a way to display or not the raster at startup and for each floor change by adding a QuickVar "NoGrid" with value "true" or "false" and launch the "raster" function conditionnaly of "NoGrid" value. Not fair code but it works👍 - for that I have also changed the "self.raster" value to "false" in SVG.lua file.
If you have a better way to do the above I will be happy to learn.
Also putting the "--%%u=..."  buttons and slider lines between --[[ ]]-- suppress the buttons and slider lines in the vscode web UI.
For the HC3 QA which is now working correctly as well:
I have use the attribute called "visible" but then QA displays blank lines where they were located so I have moved them below the image and suppress "select" line as it is not possible for the slider to hide it.
What is strange is that I have a line in the QuickApp debug window which I think is linked to "self.temps={}":
[06.03.2024] [13:40:01] [TRACE] [QUICKAPP525]: UIEvent: {"values":[2],"deviceId":525,"elementName":"sltc7","eventType":"onToggled"}
[06.03.2024] [13:40:01] [DEBUG] [QUICKAPP525]: Selected floor: 2
[06.03.2024] [13:40:01] [DEBUG] [QUICKAPP525]: createMap indx: 2
[06.03.2024] [13:40:01] [DEBUG] [QUICKAPP525]: createMap indx: 2, curr: 9
[06.03.2024] [13:40:01] [DEBUG] [QUICKAPP525]: custom [luabind::detail::null_type] object: (nil)
[06.03.2024] [13:40:01] [DEBUG] [QUICKAPP525]: No grid
What does mean that line?
Nothing similar in fibemu.
Attached the QA file
Edited by Christb
Change the fqa files due to wrong size of temp values in Yubii applications - now OK
I have another non expected issue: in the QuickApp variable table I cannot modify the variables the "pen" for opening modification is not displayed
What I need to declare in the code to prevent this?
I have found that if I am creating the QuickVar from the onInit function, then it is impossible to modify it in the QA variable pannel
So I suppressed in the code the 2 lines for the 2 variables that are static and now I can modify them manualy. 😁
I have update the attached fqa file in my previous post
As I started with your SVGtest.fqa which has been created as a binary switch the Fibaron ON/OFF buttons are there but of no use.
I tried to change its type using the Swagger but all new data are accepted except the type change.
Is this forbiden by Fibaro?
if it is the case then I will have to create a new QA with the type "com.fibaro.deviceController" and reinject all files main, SVG and images.
Edited by Christb
    No, you can't change the type of an existing QA. You need to create a new (in fibemu?) with your choice of type...
    The short answer is that if you store a value that is not a string you can't edit it.
    • Thanks 2
    It is not the first time I am asking: "Where I can find such specification?"
