Ask for Scene by Lua
mohamedsalah
    %% autostart
    %% properties
    110 stairMS
    266 stairSoptLight
    263 stairHiddenLight
    %% events
    %% globals
    jS2n={stairMS=110,stairSoptLight=266,stairHiddenLight=263} --please change stairMS and stairLight to your real device ID
    jM = {
    {5,"`stairMS`",{state="value=true",timeSlot="17:00~07:00",timeSpanOn=true,
    trueAct={"`stairSoptLight`|`stairHiddenLight`","turnOn",""},
    timeLoopAct={"`stairSoptLight`|`stairHiddenLight`","turnOff","","{`stairMS`:valueModified>1200|`stairSoptLight`,`stairHiddenLight`:value=true}"}}},
    thats still not work??
    and no error come
    No,no no... you need to download and copy entire
    to blank Lua scene window.
    Then you need to add to :
    jS2n { stairMS=110,stairSoptLight=266,stairHiddenLight=263 }
    jM{} - {5,"`stairMS`",{state="value=true",timeSlot="17:00~07:00",timeSpanOn=true,
    It should look like this:
    Again, all code should be part of scene.
  • aha, sorry my bad ??
    Excuse me, this is my first time using it lua code
    I started installing fibaro devices
    A year ago but that first time to using the lua scene ??
    Now I use HC2 and HCL in the same building because it is made up of two floors. I put HCL on the second floor, which is also linked to the motion. I want to do the same previous process, but the light it on the second floor.
    jS2n={lobbyMS=328,lobbySoptLight=331}
    jM = {
    {5,"`lobbyMS`",{state="value=true",timeSlot="17:00~07:00",timeSpanOn=true,
    trueAct={"`lobbySoptLight`","turnOn",""},
    timeLoopAct={"`lobbySoptLight`","turnOff","","{`lobbyMS`:valueModified>1200|`lobbySoptLight`:value=true}"}}},
    I think lua scene in HCL cannot be done but if it is bound to HC2 can it be done??
    1.Please don't use Master devices. They are not have states or actions.
    2. No Lua scenes in HCL available.
    If HCL is a remote gateway to HC2 do you see HCL devices in HC2? If yes, I think you can use it. Let's try.....
    I'll try to help as much as possible.
  • okay now id for motion in HCL is 87
    and after i make connection between HC2 and HCl same id for that motion change for 328
    what can i do for that to make it work in lua  scene as the first one ?
    i think i need to try to make the same code but change id for devices as id in hcl !!!? ?
    So in HC2 this device is 382, so use it and let's see....
  • Okay but I used it before
    and that message come
    and you told me don't use Master devices put in HC2 i cant know how is the master device
    could you please post API device property ?
    in browser http://<HC2-IP>/api/devices/382
    Edited by cag014
    No... The link doesn't help (login security)
    please execute on your browser
    copy received data and post it.
    OK..post it when available
  • http://192.168.0.106/fibaro/en/devices/configuration.html?id=328
    Sorry for being late
    I cannot use your local link..
    Executed this link on your browser copy the screen and post it.
