LUA script for Sonos
Hitman_85
Hello everybody,
I climbed from HC 2 to HC 3. Actually I thought it would be possible to trace all the scenes. Unfortunately, Fibaro has adapted the LUA Editor. Since then I have tried unsuccessfully to put the IFTTT webhook trigger that I had set up for Sonso back on the Fibaro keyfob. Can anyone help me what exactly I have to enter for a LUA code on the "Action" page ????
Hitman_85
Edited by Hitman_85
fehler
10 hours ago, cag014 said:
@Tony270570, @robw
Guys I think you have Sonos and probably familiar how to control it... any help is welcome.
Thanks in advance
@Hitman_85
By the way there is plugin for Sonos in HC3, did you try it?
I will try to look into this, but I can´t promise when. I am not a coder so it is slow work for me. I have added the Sonos plugin and it works. But I haven't done any code to control it by myself yet. I will try to make a "Wake up clock" someday :)
    13 hours ago, cag014 said:
    go tot devices-> add->other devices
    Scroll all over the page or choose type.
    Well, this is not entirely true. You can activate all plugins' buttons (including volume) using Lua scene and QuickApp getMyHttp.
    Do you want to try it? I'll provide buttons' url
    The problem is that I just have no idea about LUA. It is not clear to me how I build your template, the plugin, into an LUA scene. Could you create a template that I can easily include as a beginner?
    OK.. I'll post a scene that works with QQ template.
    Meanwhile could you please upload the getMyHttp.fqa  into system and post the ID number
  • The ID of getMyHttp is 54 and of Sonos Plugin 50. My Keyfob have the ID 48. Thank you in advance for your support.
    On 2/17/2020 at 8:54 PM, cag014 said:
    @Tony270570, @robw
    @cag014 Sorry I didn't answer to you !! What are your trying to achieve exactly. how can i help ? to be trensparent i was using sonos mainly for TTS, but i switched to Alexa. Cheaper...
    Thanks for your reply.
    It's OK, we're trying to use Sonos plugin now.
    I'm curious how you've switched to Alexa ?
    Edited by cag014
    @cag014 with Sonos i was using @Krikroff VD, tell me if you need extra info.
    Regarding alexa I'm using this:
    it work nicely and absolutly fast. It just has a limitation, you should predefine the text and can't compose it dinamically, but except that it's really cool and cost less then a sonos for tts few euros per year.
    And the support is great ;)
    Thanks for sharing...
    For me predefined text, it is pretty "big" limitation. I'll stick with Android... any text anywhere.
    9 minutes ago, Tony270570 said:
    I fully understand @cag014, I hope that one day or another the skill will be able to handle this functionnality.
    Let's hope fibaro will add that to HC3. I have exchanged few emails with them on that and at the end they said they'll consider this option.
    Agree. By the way since HC3 doesn't have speaker output, I've suggested to route TTS to mobile/tablet application.
    @Hitman_85
    Since we're using plugin, getMyHttp is not required (I hope)
    Let's try one action, please follow next steps:
    1.  Make sure correct IP defined in plugin of your Sonos speaker.
    2.  Start to play some music on Sonos and pause it. I mean on Sonos speaker itself.
    3. Create lua scene.
    4. Insert line below in "Actions" section of Lua scene
          5. Insert lines below in "Declarations" section of Lua scene
     6. Press "Save"
    7. Now press key 4 on key fob. Sonos should start to play.
    Let me know if it works?
    Edited by cag014
    12 hours ago, cag014 said:
    @Hitman_85
     6. Press "Save"
    The Fibaro Sonos plugin provided on the HC3 supports
    fibaro.call(<sonosID>,"play")
    fibaro.call(<sonosID>,"stop")
    fibaro.call(<sonosID>,"pause")
    fibaro.call(<sonosID>,"setVolume",<volume>)
    ...what I could find...
    On the other hand, if retrieving the definition (api.get("/devices/<id>")) it shows that it should support action turnOn, turnOff, and setVolume - and the 2 first doesn't work.
    Since I don't have Sonos speaker, my observation based on data from API and no actions were listed there.
    By refreshing the page actions appeared... bug in hc3?
    So @Hitman_85 use as suggested by @jgab
    Replace line
    by
    Edited by cag014
    Thank's to @jgab and @cag014, here is a very simple Sonos Wakeup scene. It triggers by an exact time, on the days chosen. In this example it runs on Mondays, Tuesdays, Wednesday, Thursdays and Fridays, and the Sonos starts playing at 05:55 AM. It plays for 15 minutes (set in Actions fibaro.setTimeout) and then stops. Change your Sonos ID to your own number. In the example it is 99 in fibaro.call in Actions.
    Put the code below in Declarations:
    conditions = { {
    isTrigger = false,
    operator = "match",
    property = "cron",
    type = "date",
    value = { "*", "*", "*", "*", "1,2,3,4,5", "*" }
    isTrigger = true,
    operator = "match",
    property = "cron",
    type = "date",
    value = { "55", "05", "*", "*", "*", "*" }
    operator = "all"
    Put the code below in Actions:
    fibaro.call(99, 'play')
    fibaro.setTimeout(900000, function()
    fibaro.call(99, 'stop')
    end)
    conditions = { {
    isTrigger = false,
    operator = "match",
    property = "cron",
    type = "date",
    isTrigger = true,
    operator = "match",
    property = "cron",
    type = "date",
    operator = "all"
    end)
    It's possible to combine the conditions. I don't understand why they don't do it in the examples in the manual.
  • I'm still having problems ... The scene works with fibaro.call (50, "play"), but it doesn't work with the keyfob. When I start the scene once, the buttons react. Strangely, when you turn it off, the first song in the playlist is played again. Does anyone know why?
    Declarations
    conditions = { {
    id = 48,
    isTrigger = true,
    operator = "==",
    property = "centralSceneEvent",
    type = "device",
    value = {
    keyAttribute = "Pressed",
    keyId = 4
    operator = "all"
    Aktion
    fibaro.call(50, "play")
    Is your scene in Auto mode?
  • No, the scene is on manual. Would this be wrong?
    Edit:
    I also just tried it on automatic. With the X on the keyfob, the music starts again at the beginning of the playlist, although it should actually stop.
    Edited by Hitman_85
    Ergänzung.
